problem with load combination
7 REPLIES 7
Message 1 of 8
rodainnajjar1229
984 Views, 7 Replies
dear all
kindly  review  pic1/2
i have problem with load combination  ,at  first I used  nonlinear analysis but when stop it and  use full automatic combination after that no loads in case dialog, kindly help us
7 REPLIES 7
Message 2 of 8
Automatic combinations are generated in linear model only
or use Manual Combiantion generator
Rafal Gaweda
Message 3 of 8
can we change anlysis type ??
Message 4 of 8
Yes, if there is no nonlinear object \ element \ property in model.
Rafal Gaweda
Message 5 of 8
dear sir
kindly find attached file
i tried change anlysis type but i can t
Message 6 of 8
You need to switch off the aux case definition.
Artur Kosakowski
Message 7 of 8
in reply to: rodainnajjar1229
I have the same problem.i can not  load combination.i have been using EN 1990 : 2002 for project.Please advise!
Message 8 of 8
Rafal.Gaweda
