Hi support team, I would like to ask about my model.From analysis,my model is free from instability issue.but i'm curious about my displacement.some point showing irregular value. file is attached.
one more thing, when i'm checking required reinforcement, the button for 'manual combination' is disable. can anyone help me?
https://www.dropbox.com/s/9x2u6pgn8hfy55h/20130614-GREENWOOD%20%28cladding%29.rtd
Hi
You already defined ULS combination. See the attached file
actually I don't know how to explain my problem. But my case is similar to this post (link below)
From the message thread, there is no solution. Currently I'm using RSA pro 2014.
I do not understaned what do you mean by that.
BTW : loads from cladding 166 are not applied becasue either cladding is not defined in bars plane or bars are not modeled in claddings plane
Hi Rafal, what do you mean by 'loads from cladding 166 are not applied becasue either cladding is not defined in bars plane or bars are not modeled in claddings plane'. Can you explain with picture please (or other ways).
No tributary area is generated on this cladding.
Look below.
