Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Problem with design combinations
1 REPLY 1
andrea_pontiggia
286 Views, 1 Reply
I changed some coefficients normally to generate personal combinations. Robot does not generate seismic combinations. Even changing legislation fails to create design combinations. What can I do? thanks
Andrea
1 REPLY 1
My assumption is that you  want to generate automatic combinations. PLease check if you have all relations for each nature of loads correctly defined.
Artur Kosakowski
