I changed some coefficients normally to generate personal combinations. Robot does not generate seismic combinations. Even changing legislation fails to create design combinations. What can I do? thanks
Solved by Artur.Kosakowski. Go to Solution.
My assumption is that you want to generate automatic combinations. PLease check if you have all relations for each nature of loads correctly defined.
