Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Problem with cross section orientation
1 REPLY 1
Invictus22
378 Views, 1 Reply
I have already imported the cross section i want from Autocad to Robot and saved into the Robot database.
The problem is that, when i apply that section to a bar, the section is not in the orientation i want. For example, the weakest axis is resisting to the strongest bending moment.
How can i rotate the section in Robot so i can have the most efficient structure?
Thank you in advance!
1 REPLY 1
Rafacascudo
in reply to: Invictus22
Geometry/properties/gama angle
Rafael Medeiros
