I have already imported the cross section i want from Autocad to Robot and saved into the Robot database.
The problem is that, when i apply that section to a bar, the section is not in the orientation i want. For example, the weakest axis is resisting to the strongest bending moment.
How can i rotate the section in Robot so i can have the most efficient structure?
Thank you in advance!
Solved by Rafacascudo. Go to Solution.
Rafael Medeiros
