Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Problem with coverings
3 REPLIES 3
andrea_pontiggia
243 Views, 3 Replies
I can not understand why in the calculation model which is attached panels 351 353 354 and 363 do not share the load.
The model is imported from Revit, but the other panels are correct.
Andrea
3 REPLIES 3
The reason is setting the user defined tolerance for model generation as 0.  Any particular reason for that ?
Anyway I have asked the development team to disable such possibility in the future.
The solution is e.g. to change to Automatic instead.
Artur Kosakowski
How can I set the automatic mode?
Andrea
Artur Kosakowski
