Discussion Groups
Robot Structural Analysis
10 Kudos
Problem with coverings
119 Views, 3 Replies
12-17-2012 08:25 AM
I can not understand why in the calculation model which is attached panels 351 353 354 and 363 do not share the load.
The model is imported from Revit, but the other panels are correct.
Andrea
Product Support
759 Kudos
Re: Problem with coverings
12-18-2012 12:50 AM in reply to: andrea.pontiggia
The reason is setting the user defined tolerance for model generation as 0.  Any particular reason for that ?
Anyway I have asked the development team to disable such possibility in the future.
The solution is e.g. to change to Automatic instead.
Artur Kosakowski
10 Kudos
12-18-2012 01:32 AM in reply to: Artur.Kosakowski
How can I set the automatic mode?
Andrea
Product Support
759 Kudos
12-18-2012 01:44 AM in reply to: andrea.pontiggia
Artur Kosakowski
