hello!
In eurocode ec 1993-1-8 on fig. 6.11 value of alpha is max 8 min 4.45.
when i checked the connection beam to column the leff,nc is 225.3631......
225,3631/22,9=9.84>>8
please check the values and give me a answer...
Thank you!! (forgive my English)
Solved by Artur.Kosakowski. Go to Solution.
Is the 5th row the one close to the stiffener or the internal one? I think that for the 5thnone you should use another formulas from the table you attached.
- for example, the second row in the figure above, the column flange, the effective length of time a program is 207.1506 and m = 22.9, so alpha is 9.045>>8, (leff,nc=alphaxm).
- Please mark the figure that the formula uses to turn two screws (for column flange onlly) in the given situation in figure
I attached above values of calculation parameters required to determine the value of alpha
Thank you, and I appreciate that you answered
So where wrong interpretation results provided by the program?
Sorry for the insistence, but I need to know.
Thanks for understanding!
Currently Robot extrapolates the values of alpha 'above' 8 and 'below' 4.5. I have asked the development team to investigate this situation. Thank you for reporting it.
Thanks for the reply.
It would be a problem to the combination of steel poles with concrete foundation., But this I will post it in the coming days ....
Back with a question...
It can disable analysis by C.B.E, for:
P100-2011 is the equivalent EN 1998 (in my country)
Thank you!
Let me answer this question after the release of Robot 2015
Thank you!
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Connections-Column-base-design-concrete-rein...
Thank you!
This verificaton can be switched off in Robot 2015
Corrected in SP1 for Robot 2015.
