Solved by Rafal.Gaweda. Go to Solution.
You can add this from here .
Firstly , you should go to job preferences >> design codes >> loads >> seismic loads and choose your code
heloo dear sir
i am looking forwared to do ( sismic equivelent method )by useing some code as UBC or an code i need
so please tell how can i add it
you can see this attachment
thank you
Only the codes shown on your screen capture are implemented for this method.
so sir what do you advice to do calcolation by using UBC as an (equivelent method )
Again thank you help
Use ordinary seismic calculations
what do you mean by ordinary seismic from where i can do it in robot can you show me please
