Problem in panel meshing
3 REPLIES 3
fmp999
434 Views, 3 Replies
I am having some problems in creating the mesh for the panel in the zone of intersection of bars for the model that i attach the link file.
http://www.4shared.com/rar/5T0h4DWyce/Forum_3D.html
My predifined meshing options are the folowing ones:
The iterative method is chosen to obtain coherence, but i am still having some problems creating the mesh, like isoloted nodes and incoherences in some nodes.
Whats your advise to solve these issues in the modeling process.
Thank you,
3 REPLIES 3
Artur.Kosakowski
in reply to: fmp999
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
fmp999
in reply to: Artur.Kosakowski
Thank you for the help, but  when i run the analysis a message of instability type 3 appears, should i ignored it?
Artur.Kosakowski
in reply to: fmp999
I think you can as it seems to be caused by the large difference in stiffness of elements. When you delete panels (therefore no short bar elements are generated due to meshing) no instability is reported. As always in such situation you should carefully check the obtained results to make sure they are as expected.
Artur Kosakowski
