Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
problem importing load combinations for RC Design Provided Reinforcement
1 REPLY 1
memoalcr
876 Views, 1 Reply
In RSAPro2013 for a RC Design with Provided Reinforcement, when the "Columns-Parameters for RC Elements" window appears the "Manual Combinations" option is grayed out (see attached picture). The program selects de "Simple Cases" option.
If I click the OK button a "Value out of limits" warning displays right after.
For the selected member the "Loads" window is empty.
If I run the calculations, a "Calculations Errors" window displays with the following message:
"Code combinations: Simple load cases have not been defined"
Why is RSAPro2013 not importing the defined combos into the RC Design Module?
1 REPLY 1
Artur.Kosakowski
in reply to: memoalcr
Most likely you haven't defined any manual combinations.
I need the rtd file to look at.
Artur Kosakowski
