Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Problem for creating new Steel Profiles in Robot Professional
4 REPLIES 4
425 Views, 4 Replies
I want to create a profile which is a kind steel pipes but with a little complex shape. I make the drawing as dwg file, creating the outside lines, and when I import it to Robot, it recognises as two different lines if I import it as thin section, and as a full piece, it does not recognise the inside line and makes it as a full solid piece. It allows me to make it correctly for non closed profiles, but not to closed ones. Is there anyway I can do as i want?
Also I try to make the piece as a thin profile, it only allows me to do it with 2mm thickness. How can I change the thickness for the thin profiles?
Thanks in advance.
4 REPLIES 4
Thanks in advance.
Rafal.Gaweda
Send us this dwg file
Rafal Gaweda
in reply to: Rafal.Gaweda
I send attached two examples of dwg I tried to use for creating profiles.
With the first one I wanted to make a 2mm thick profile and with the second
5mm thick.
Regards
Dpto T?cnico
Asthor Agr?cola S.A.
C/ M? la Pondala, 41
33393 Gij?n
Principado de Asturias - Espa?a
Tel.- +34 985 30 37 52 Fax.- +34 985 30 37 53
www. asthor.com
Artur.Kosakowski
1. Draw an inner contour that will create the opening
2. Select the object and press right mouse button to change thickness
Artur Kosakowski
