Hi!
I am modeling a bridge using beam sections that I created in the "Section Definition" menu. Sometimes it works fine, but most of the times, after I run the calculations the bars lose their properties, at least in the properties table (image attached) or their properties is changed to the shell proporties used in the same model. But as you can see in the images, the bars seems to be ok. I don't know what to do about that, because even if I try to change the properties again manually, it changes again when I run the calculations, or sometimes it doesn't change at all.
Even with this problem, my model works fine apparently. But I don't know if I can trust in the results because of that.
I am attaching 3 pictures, one that shows one model ok, after the calculations. One that shows another model not ok. One that shows one beam that lost its properties and I tried to attach one that show another beam in the same model that changed its properties for the shell properties.
Hope I explained well everything and you can help me with that.
Thank you very much!
Murilo
Solved by Rafacascudo. Go to Solution.
The model is too big, but here is a link to a google drive folder:
https://drive.google.com/folderview?id=0B2h9hlUzaAZeSGg1ajR4Znc1NEE&usp=sharing
Thanks!
save with another name and without results and zip it.
This was the model with no problems, right??
Send the one with problems!!
Brasileiro ou Português?
Rafael Medeiros
Robot Structural Analysis
Brasileiro. Assuming you speak portuguese too, I'm gonna write in portuguese.. If not, I can translate it.
Poisé, ontem quando verifiquei 14 arquivos que eu tinha feito, 12 estavam com aqueles problemas (incluindo esse que enviei na pasta) e 2 estavam certos. Verifiquei agora alguns deles de novo e percebi que alguns nao aparentam mais os erros, enquanto que esse que eu estou enviando agora (que estava certo), está errado.
Então isso ta me confundindo bastante, pois como disse os resultados parecem fazer sentido, mas não tenho certeza se posso confiar totalmente por causa disso. Sem contar que as vezes o programa não faz as modificações das propriedades que eu tento fazer.
Valeu!!
Verifiquei de novo, e apareceu o problema nesse também.
Murilo , tambem sou brasileiro. Bem vindo , somos poucos aqui!
Parece ser um bug da janelinha "object inspector " . repara nas figuras abaixo que na janela de " object properties " e tb na tabela " bars" tá tudo correto pra esses 2 ultimos modelos.
E tb qdo vc seleciona as barras pela seção type 4 ou 5 , todas são selecionadas.
Alem disso ,se na janela grafica vc mandar aparecer a bar description , vai aparecer tudo certinho nas 4 vigas.
É estranho mas Acho que pode ficar tranquilo.
Translating...
Murilo , I´m also brazilian , welcome , We´re just a few here!!
It seems to be a bug on " object inspector " window. Look in the pictures below that the " object properties " reports the correct bar section. Also in hte bars table ,everything is correct for these 2 models.
Also in the graphic window , bar descriptions assigns the correct name for all bars and also , if you select the bars by cross section ,all bars will be selected.
It´s weird but It should be fine , I think.
Rafael Medeiros
Rafael, muito obrigado! É um prazer! Infelizmente alguns programas não são muito difundidos no Brasil como em outros países.
Mas voltando ao problema, era o que eu imaginava mesmo.. os resultados fazem sentido, mas esse probleminha faz com que eu tenha um pouco mais de trabalho por não conseguir editar uma seção ou material e verificar se possui algum erro. Mas tudo bem, pelo menos acho que posso confiar no resultado.
Agradeço muito a ajuda mesmo!
Translating:
Rafael, thank you! It's my pleasure. Unfortunately some softwares are not widespread in Brazil like in other countries.
But back to the problem, that was what I imagined. The results make sense, but this problem gives me a little more work because I can't edit a bar section or material and check if there is any mistake. But that's ok, at least I think I can trust in the results.
Relly appreciate your help!
Murilo
Boa noite a todos!
Como é feita a modelagem das vigas com essa seção transversal?
Tenho tentado fazer, mas sem sucesso.
Tools/Section definition an then Contour/Polygon
Or you can draw the section in autocad and then File/Import dxf
After the section is built , save it to Ruser database
On main RSA program ,you can import it using New section dialog
Rafael Medeiros
