Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Printout composition query
2 REPLIES 2
sanjuan100
279 Views, 2 Replies
Dear sirs,
I'm doing a printout composition in Robot and I'm having the problem below:
In the "standard" tab there is the option to select "Reactions ULS: global extremes" which gives the envelope for the ULS cases. However, if you want SLS (or ACC) you can select the item and edit it once it's been added to your report composition.
The problem I have is that when I do this it still prints the table for the ULS cases.
Is it possible to know how I can do it for SLS or ACC? is there a different way or does it need a software update or similar?
I'm using Robot 2015 v28.0.0.5335.
Thank you, kind regards,
sanjuan100
2 REPLIES 2
Rafacascudo
in reply to: sanjuan100
goto tables /reactions , select whtaever you want , take a screen capture , goto printout composition and it will be on screen captures tab
Rafael Medeiros
sanjuan100
in reply to: Rafacascudo
of course! thanks very much Rafa!
