Dear sirs,
I'm doing a printout composition in Robot and I'm having the problem below:
In the "standard" tab there is the option to select "Reactions ULS: global extremes" which gives the envelope for the ULS cases. However, if you want SLS (or ACC) you can select the item and edit it once it's been added to your report composition.
The problem I have is that when I do this it still prints the table for the ULS cases.
Is it possible to know how I can do it for SLS or ACC? is there a different way or does it need a software update or similar?
I'm using Robot 2015 v28.0.0.5335.
Thank you, kind regards,
sanjuan100
Solved by Rafacascudo. Go to Solution.
goto tables /reactions , select whtaever you want , take a screen capture , goto printout composition and it will be on screen captures tab
Rafael Medeiros
