Welcome to Autodeskā€™s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Principal View lost
4 REPLIES 4
rioja
344 Views, 4 Replies
Principal View lost
Hi all
In this file I have lost my principal geometry view layout
The only posibility to handle the elementes is to have a View:1 / Sellect All and "Edit in new Window"
How to recover the principal View, it should be undeletable isnĀ“t
Then I have do something wrong
Best Regards
Marcelo
(The attached file is without results) Due to restriccions, the file is too large to upload
4 REPLIES 4
rioja
in reply to: rioja
I have left only one beam, erased all in the RC module designed beams columns and foundations
the actual file size is 58Mb compressed 3.8Mb (the .rtd original file size is 228Mb)
Can you tell me how to reduce the file size in order to upload this file
se2p
in reply to: rioja
Save it with another name
rioja
in reply to: rioja
Thank you
I have already done twice changing the file name, saving without results, deleting the elements, leaving only one bar
saving again with another name
After selecting all, copy, paste on a new file it tooks only the bar elements but not the panels
Artur.Kosakowski
in reply to: rioja
Try to change the structure type to Solid (Geometry > Structure type) and then back to the one you work with.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
