Discussion Groups
Robot Structural Analysis
Distinguished Contributor
athurD
Pressure under foudation raft???
420 Views, 9 Replies
10-05-2012 07:54 PM
Hi all.
I is prolem, I think Pressure under foudation raft >0. Why results Pressure Robot <0 ???????
Please use plain text.
Valued Mentor
tony.ridley
Re: Pressure under foudation raft???
10-07-2012 11:04 PM in reply to: athurD
Because it's a reaction?  Under vertical load, a pinned column will have +ve reaction.  So under applied load, a soil will have a +ve reaction too?
athurD
10-07-2012 11:52 PM in reply to: tony.ridley
Thank tony.
So now I have to do to pressure under the foundation raft <0 ??. This is an image of my model .
Product Support
Artur.Kosakowski
10-08-2012 12:27 AM in reply to: athurD
As you are supposed to tell in which direction the uplift is possible you should set UZ+ rather than UZ- (at least for a typical building :smileyhappy:).
Artur Kosakowski
athurD
10-08-2012 01:54 AM in reply to: Artur.Kosakowski
Thank Artur.
i selection U+.
But why Run it too long, is there a way to make it run faster???
athurD
10-08-2012 02:10 AM in reply to: athurD
Hi. i is prolem.
How do I know choose U + or U- ??????
Product Support
Artur.Kosakowski
10-08-2012 02:11 AM in reply to: athurD
You can try to use the multi-threaded solver.
Artur Kosakowski
Product Support
Artur.Kosakowski
10-08-2012 02:14 AM in reply to: athurD
1. Check what is the orientation of the local Z axis of the panel
2. If you want to allow the panel to move (be uplifted) in the direction of the positive Z axis then you select UZ+. Otherwise UZ-.
Artur Kosakowski
athurD
10-08-2012 02:16 AM in reply to: Artur.Kosakowski
Hi.
      "You can try to use the multi-threaded solver."
Sorry I do not quite understand, can you give me an picture example.
thank Artur
Product Support
Artur.Kosakowski
10-08-2012 02:57 AM in reply to: athurD
Artur Kosakowski
