Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Pressure under foudation raft???
9 REPLIES 9
Message 1 of 10
athurD
875 Views, 9 Replies
Hi all.
I is prolem, I think Pressure under foudation raft >0. Why results Pressure Robot <0 ???????
9 REPLIES 9
Message 2 of 10
in reply to: athurD
Because it's a reaction?  Under vertical load, a pinned column will have +ve reaction.  So under applied load, a soil will have a +ve reaction too?
Message 3 of 10
athurD
Thank tony.
So now I have to do to pressure under the foundation raft <0 ??. This is an image of my model .
Message 4 of 10
Artur.Kosakowski
in reply to: athurD
As you are supposed to tell in which direction the uplift is possible you should set UZ+ rather than UZ- (at least for a typical building Smiley Happy).
Artur Kosakowski
Message 5 of 10
athurD
in reply to: Artur.Kosakowski
Thank Artur.
i selection U+.
But why Run it too long, is there a way to make it run faster???
Message 6 of 10
athurD
in reply to: athurD
Hi. i is prolem.
How do I know choose U + or U- ??????
Message 7 of 10
Artur.Kosakowski
in reply to: athurD
You can try to use the multi-threaded solver.
Artur Kosakowski
Message 8 of 10
Artur.Kosakowski
in reply to: athurD
1. Check what is the orientation of the local Z axis of the panel
2. If you want to allow the panel to move (be uplifted) in the direction of the positive Z axis then you select UZ+. Otherwise UZ-.
Artur Kosakowski
Message 9 of 10
athurD
Hi.
      "You can try to use the multi-threaded solver."
Sorry I do not quite understand, can you give me an picture example.
thank Artur
Message 10 of 10
Artur.Kosakowski
in reply to: athurD
Artur Kosakowski
