Hi all.
I is prolem, I think Pressure under foudation raft >0. Why results Pressure Robot <0 ???????
Solved by Artur.Kosakowski. Go to Solution.
Because it's a reaction? Under vertical load, a pinned column will have +ve reaction. So under applied load, a soil will have a +ve reaction too?
As you are supposed to tell in which direction the uplift is possible you should set UZ+ rather than UZ- (at least for a typical building ).
Thank Artur.
i selection U+.
But why Run it too long, is there a way to make it run faster???
1. Check what is the orientation of the local Z axis of the panel
2. If you want to allow the panel to move (be uplifted) in the direction of the positive Z axis then you select UZ+. Otherwise UZ-.
Hi.
"You can try to use the multi-threaded solver."
Sorry I do not quite understand, can you give me an picture example.
thank Artur
