Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
pressure load
3 REPLIES 3
rodainnajjar1229
480 Views, 3 Replies
pressure load
dear sir
when i applay pressure load on any walls in model ( pic 1)  results as follow :
-no problem with displacements Z self weight (pic 2)
-illogical displacements Z & X & Y ( pic 3-4-5)
regards
Tags (1)
3 REPLIES 3
Have you defined any horizontal restrains or only the vertical supports?
Artur Kosakowski
dear sir
kindly find attched file... only i used raft foundation kz=30000
but retaining walls fixed by 2 floors up & bottom and there is illogical displacements Y& X
regards
Tags (1)
@rodainnajjar1229 wrote:
dear sir
kindly find attached file... only i used raft foundation kz=30000
regards
But what 'fixes' the walls or the entire building in the horizontal direction as there are no such supports? Please try to define some horizontal restrains e.g. modifying the elastic soil definition by entering e.g. 10000 values in the indicated fields.
Artur Kosakowski
