Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Precast concrete slabs
2 REPLIES 2
1535 Views, 2 Replies
I have  a steel frame model . I want to create precast concrete slabs and correct to frame. I don't know the way to model types this slab . For cast concrete slab in site . I just  drawing  a big slab and not divide to many part. How about precast concrete slabs ? is it the same cast concrete slab in site? Please advise!
2 REPLIES 2
Artur.Kosakowski
You need to think what kind of connection you have got among these slabs. If they act together in the same way as the cast concrete one you can use a single panel. Otherwise you may need to define them as separate panels with some releases or gaps along their edges.
Artur Kosakowski
in reply to: Artur.Kosakowski
Hi all
Please create a tutorial to create model analytical from physical model for precast concrete include: precast beam, column, panel. Then design connection in robot
Thanks all
