bsr,
pouvez me montrez comment est ce qu'on arrive à transférer le moment d'une semelle excentrée àune poutre de redressement.
merci.
Solved by Artur.Kosakowski. Go to Solution.
There is no automatic transfer of moments from spread footings to ground beams. This has to be done manually as additional loads applied to such beams.
