Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Possible error in steel connection design module
3 REPLIES 3
Mirko.Jurcevic
453 Views, 3 Replies
Hello!
I have a problem (maybe it's bug), it's not big deal but it looks bad in front of clients during presentations.
When I define steel connection, some images (schemes) of connection parts are not placed correcty.
Scheme, Connection View and Results are ok. I'm attaching images to be more clear.
Not all images of connection parts are wrong, just those attached and some similar to them.
Software:
Robot Structural Analysis Professional 2013 (Autodesk Building Design Suite Ultimate 2013) Version: 26.0.3.4375 (x64)
Hardware:
Windows 7 Professional SP1 64bit, Intel i7 CPU 2,70 GHz, 16GB RAM, SSD
Is there a solution for this?
Thanks!
Mirko
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
3 REPLIES 3
Looking at the attached pictures it seems that you work with English interface but what is the output language you set?
Have you made any change in the size of fonts in Robot Preferences?
Artur Kosakowski
Input & output language is English.
Regional settings: Eurocode
And I haven't change size of fonts or any other visual property. I've using it as-is.
Should I try changing fonts? Or languages?
Mirko Jurcevic
Please check the private message folder.
Artur Kosakowski
