Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Possible error in steel connection design module
1 REPLY 1
bjornhgr
796 Views, 1 Reply
I'm designing a steel roof structure using Robot 2012 x64 on Win7. When designing steel connections (column base) the program seems to confuse tensile and compressive forces. I've attatched screen captures from a test I've made. When calculating the connection with pure compression, the results are given for tensile capacity.
Am I missing something vital, or is there an error in Robot?
Thanks!
Bjørn G.
Norway
1 REPLY 1
Artur.Kosakowski
in reply to: bjornhgr
Please download and install Service Pack 1+2 Hotfix
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17847332&linkID=13140816
Artur Kosakowski
