Hello, I noticed that assigning point load with angles around global X,Y and Z is not assigned properly.
I created a simple model for a load on point with some angles around X,Y and Z and then saved the model as DWG, I then opened the file as drawing and measured the angles of the load arrow about X,Y and Z and I found totally different values as per the attachment.
Please review and advise what is wrong!
Solved by Rafal.Gaweda. Go to Solution.
With 3d and 3 angles it will be a little bit more complex.
2d example
