Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Plates and shells table issue
5 REPLIES 5
Rafacascudo
328 Views, 5 Replies
See attached pictures. Table doesn´t show elastic ground / uplift ,giving zero and no values.
Rafael Medeiros
5 REPLIES 5
Rafacascudo
in reply to: Rafacascudo
With further investigation , it gets worse!!! See in the attached picture that one of my panels can have 3 different values for Kz and uplift. Same occurs to other thicknesses in this table. But , for now ,it seems to be only a table problem.
Rafael Medeiros
Rafal.Gaweda
File please.
Rafal Gaweda
Rafacascudo
in reply to: Rafal.Gaweda
attached. Rename to .rar
Rafael Medeiros
Rafal.Gaweda
Have you copied (duplicated) and renamed already applied to these panels  the panel thickness label before?
Do you remember what actions you have done on these panels in the way to apply  \ modify assigned thicknesses?
Workaround : apply Diafragma 900 Uz-   using selection of 24to48By8 5770 18854 18872 18879 20018 20028 20036
Rafal Gaweda
Rafacascudo
I don´t remember the exact order of what I´ve done , but anyway , I re- assigned every panel with its own thickness and the table is showing the correct values now
thx
Rafael Medeiros
