See attached pictures. Table doesn´t show elastic ground / uplift ,giving zero and no values.
Rafael Medeiros
With further investigation , it gets worse!!! See in the attached picture that one of my panels can have 3 different values for Kz and uplift. Same occurs to other thicknesses in this table. But , for now ,it seems to be only a table problem.
Rafael Medeiros
attached. Rename to .rar
Rafael Medeiros
Have you copied (duplicated) and renamed already applied to these panels the panel thickness label before?
Do you remember what actions you have done on these panels in the way to apply \ modify assigned thicknesses?
Workaround : apply Diafragma 900 Uz- using selection of 24to48By8 5770 18854 18872 18879 20018 20028 20036
I don´t remember the exact order of what I´ve done , but anyway , I re- assigned every panel with its own thickness and the table is showing the correct values now
thx
Rafael Medeiros
