Is there any command in robot that will change the shape of a wall by means of stretching it( imagine a rectangular wall and you try to move the upper portion only but the lower portion is fixed), the normal way of doing this, is moving/traslating the "nodes" on top and start modelling the walls and you have a slanted wall, but how about if you have rectangular wall and you want to deformed it, moving nodes is not an option(since only nodes will move leaving behind the wall).
Pls. see attched.
Maybe by editing coordinate of plate?
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
Try with graphical edit.
Select the wall and then locate the corner you want to move. Use zoom and pan for precise selection. Then click with left mouse button on the corner you want to move and drag to a new location.
Select the wall and then locate the corner you want to move. Use zoom and pan for precise selection. Then click with left mouse button on the corner you want to move; click on it again and drag to a new location.
Thanks everybody! But how about if I need a precise location/dimension,ie, 36 mm etc. My twenty story project needs the core walls" tilt" about 52 mm from the top of the 18 th floor(just to give allowance to the effect of posttensioned floors), I am also wondering, if there's a sweeping command that I can used to tilt all the walls that form the core wall in one instant(even the openings will follow as well).
Regards
Please make a sketch of the existing situation the intended change.
Hello Arthur,
The intention is to tilt the whole building 52 mm from the top with respect to base.
See attached.
REgards,
Try to use the detailed correction.
Have you looked at the picture I attached to the previous message?
Use rafal's spreadsheet it's a gem
Hello Arthur,
Thank for your immediate reply(just see the sketch).
The plane that you've created(with points/nodes 1 to 3), what is the location of points 1 to 3( do i need to copy it from the top nodes of the bldg and translate/copy it,ie,52 mm away)?Did everthing move with this command(including openings?), How can I verify that the bldg really tilts,ie, 52 mm? Again thank you very much
Hello Arthur,
Just seen the attachement, how do you create the intended plane(nodes 1,2 & 3), do you copy it from the top of the bldg and translate it away,ie,52 mm?Does the whole bldg moves(including openings etc.) with that command?How can I verify it that it really tilts,ie, 52 mm?
Again, thank you very much.
It can be done like this or you just type the values knowing where your structure should finally end up.
Only the objects within the given tolerance (distance from the indicated plane).
What about comparing the new coordinates with the old ones?
Hello Artur,
I've tried the procedure for a simple box type structure(four walls) but it doesnt tilt? Am I missing something here?
Hello Arthur,
This is what happen, only the 2 side walls move(I thought the whole upper portion of the wall should move not"one" side only), leaving behind the two walls.
REgards,
