I am quickly trying to see whether buckling of the plate will be a governing case for a simple connection that I am looking at.
I just wanted to check that my approach was correct for this...
I have modelled everything in Shell type structures so that I have all degrees of freedom available. I have then applied the self weight (almost negligible) and a point ULS live load (hence why the factor in the load combination is only 1).
I have selected non linear buckling analysis in my analysis parameters and run the analysis for 10 mode shapes.
I have then looked at the mode types to see which are applicable to the type of loading that is applied (for the attached model I believe that modes 6, 8 and 9 are applicable and because of other factors for me case 8 is really the critical one).
I have then opened up the critical loads table and checked the coefficient for buckling at the critical case which appears to be approx. 330 for a 16mm thk plate (despite this thickness being called 12thk - i upped this to reduce the plate stresses). 330 Seems like a very high factor for this situation, it means that a load of approx. 1420kN would be required to induce buckling which seems unlikely and hence my trepidation.
I attach my model for you to have a look at.
Any help would be gratefully received.
Richard
Richard,
Maths gives you results as shown below
From engineering point of view you should
look at positive values -> most dangerous are always coeffs <= 1.
In your case the firts positive is 103.
English is not my native language 😉 you know but I mean "mathemathical calculations"
http://en.wikipedia.org/wiki/Mathematics
Ah OK. sorry I wasn't trying to be rude!
but thanks for the link anyway!
