I always get "not lying on the same plane" error. I tried to do model correction but nothing happened. Maybe I did it wrong, but I tried all the possibilities that I can find. How can I solve this?
Thank you
Solved by Rafal.Gaweda. Go to Solution.
Your panels are ACIS panels.
RC Slab Provided reinforcement does not work for such panels.
Turn off ACIS, restart robot and remodel your structure or look at required reinforcement results on current model.
