Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Planar load on bars
3 REPLIES 3
Romanich
392 Views, 3 Replies
Planar load on bars
 Hi, I wonder why load is distributed an unexpected way?
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
3 REPLIES 3
Rafal.Gaweda
in reply to: Romanich
Do not use this load
Use cladding load instead.
Rafal Gaweda
Romanich
in reply to: Rafal.Gaweda
But it is dangerous for new users in Robot.
Roman Zhelezniak
Artur.Kosakowski
Robot generates the anisotropic planar load on bars in the following way:
  • Based on the list of elements, given in the definition of the load, the convex polygon is built with the vertexes in the nodes of the elements from the list.  In the general case this polygon may be assembled with the group of smaller polygons, which sides are the bars from the loaded bars list.
  • For the defined angle of anisotropy, the row of the virtual bars, which intersect with the edges of polygons, is generated in the defined direction.  It is assumed that the sheathing has the rigidity only in this one direction.  The rigidity in the perpendicular direction is not taking into account.  The length of the segments of the bars between the intersections with the polygons, influences directly the value of the load applied to the corresponding segment of the polygon edge.
  • For the general case, on the given edge, separate trapezoidal loads may be generated on the separate segments.  In order to not generate too many load data, one statically equivalent trapezoidal load is defined on the whole edge of the polygon.
  • In case, that the polygon edge is identical with the bar element, the load is applied directly to this bar.  In case, that the polygon edge does not correspond to any bar, the load on this edge is replaced with the statically equivalent set of concentrated forces at the end of this edge.
In case of the isotropic load, the series of anisotropic load generation is performed, with the angle of anisotropy changing every 15 degrees.  After that the average results for every anisotropic case are treated as the isotropic case
Artur Kosakowski
