Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
planar load 3p on circular diaphragm wall
1 REPLY 1
347 Views, 1 Reply
Please help me to manual define the load on a circular diaphragm wall. It't look like the attached pic.
I must use earth pressure or I can just define it by planar load 3p?
1 REPLY 1
Artur.Kosakowski
You can use the later one but you have to be carefull selecting the points you indicate load values in. You may also consider using the hydrostatic load instead.
Artur Kosakowski
