Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
pile spring in compression and tension but different K value
2 REPLIES 2
luoxy
1629 Views, 2 Replies
as title, is there anyway to model supports as such? i.e. K=1,000,000KN/m in compression yet 50,000kN/m in tension?
one way go around is probably by defining 2 supports next to each other with one set Uz+ and the other one set Uz-
any comments are welcome.
2 REPLIES 2
rsousa_
in reply to: luoxy
You can define a non-linear model type linear in parameters (without symmetry) with different k values for positive and negative semi-axis...  Then assign that model name for the direction you want in support definition.
regards
Artur.Kosakowski
in reply to: luoxy
With all steps of the definition shown Smiley Happy
Thank you rsousa_
Artur Kosakowski
