Discussion Groups
Robot Structural Analysis
Member
luoxy
pile spring in compression and tension but different K value
621 Views, 2 Replies
06-19-2012 04:32 AM
as title, is there anyway to model supports as such? i.e. K=1,000,000KN/m in compression yet 50,000kN/m in tension?
one way go around is probably by defining 2 supports next to each other with one set Uz+ and the other one set Uz-
any comments are welcome.
Please use plain text.
Active Contributor
rsousa_
Re: pile spring in compression and tension but different K value
06-19-2012 04:46 AM in reply to: luoxy
You can define a non-linear model type linear in parameters (without symmetry) with different k values for positive and negative semi-axis...  Then assign that model name for the direction you want in support definition.
regards
Product Support
Artur.Kosakowski
06-19-2012 04:49 AM in reply to: luoxy
With all steps of the definition shown :smileyhappy:
Thank you rsousa_
Artur Kosakowski
