Hi all
Analyzing slabs, I get some peak values at corners. I believe this is because of uplift in corners but I am not interested in these values proceding into req. reinforcement. I use the option to reduce forces above supports but without luck.
Can someone please explain how I get these values away if possible. If its not possible, what are the workflow while bringing the slab into prov. reinforcement?
the file can be downloaded from here: https://www.dropbox.com/s/cbuzmca4y47agm7/DO1_rev03%20-%20rc%20calc.rtd?dl=0
regards
peder
Solved by StefanoPasquini6790. Go to Solution.
Hi
thanks for helping out.
I have set dimensions for the supports and in the attached file and that helped as you mentioned to. Do you have any other suggestions that could help?
Meshing options or calculation method etc?
Thanks in advance
