Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Pb with load definition
2 REPLIES 2
faisal.aaouatif
721 Views, 2 Replies
Please tell me how can i deal with this (see attachment).
which load case and wich load having problem.
thks
2 REPLIES 2
Please check the reactions table. The case that includes the incorrect load should have them displayed as not available. Depending on the number of loads you have defined within this load case you can either try to identify it graphically or create separate cases for each of the contour load. The possible reasons are the load projection defined as parallel to the contour or the contour being defined as e.g. an hour glass (X)  rather than a rectangle.
Artur Kosakowski
Managed to solve the pb.
thank you VM
