Discussion Groups
Robot Structural Analysis
70 Kudos
Pb with load definition
317 Views, 2 Replies
10-18-2012 12:25 PM
Please tell me how can i deal with this (see attachment).
which load case and wich load having problem.
thks
Product Support
758 Kudos
Re: Pb with load definition
10-19-2012 12:18 AM in reply to: faisal.aaouatif
Please check the reactions table. The case that includes the incorrect load should have them displayed as not available. Depending on the number of loads you have defined within this load case you can either try to identify it graphically or create separate cases for each of the contour load. The possible reasons are the load projection defined as parallel to the contour or the contour being defined as e.g. an hour glass (X)  rather than a rectangle.
Artur Kosakowski
70 Kudos
10-19-2012 12:01 PM in reply to: Artur.Kosakowski
Managed to solve the pb.
thank you VM
