Please tell me how can i deal with this (see attachment).
which load case and wich load having problem.
thks
Solved by faisal.aaouatif. Go to Solution.
Please check the reactions table. The case that includes the incorrect load should have them displayed as not available. Depending on the number of loads you have defined within this load case you can either try to identify it graphically or create separate cases for each of the contour load. The possible reasons are the load projection defined as parallel to the contour or the contour being defined as e.g. an hour glass (X) rather than a rectangle.
