Pattern load
2 REPLIES 2
1023 Views, 2 Replies
Pattern load
How to practically apply pattern load  from specially loads for multi-span slab in Robot 2011?
Is there any limit for slab geometry/layout when use pattern load method?
2 REPLIES 2
Artur.Kosakowski
You can try to define several live load cases with surface loads on a contours (one load in each of the load case) and then generate either automatic or manual combinations using the combination wizard (Loads > Automatic Combinations). The limit of combinations can be set in Job Preferences.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
I Think that SWModeller, want to do it in the same way that CSI SAFE is doing it, means in two way automatic patern live on the surface area of the slab, and a custon surface area simila to what you have proposed with ARSA
