Discussion Groups
Robot Structural Analysis
Active Member
SWModeller
Pattern load
370 Views, 2 Replies
08-30-2011 08:47 AM
How to practically apply pattern load  from specially loads for multi-span slab in Robot 2011?
Is there any limit for slab geometry/layout when use pattern load method?
Please use plain text.
Product Support
Artur.Kosakowski
Re: Pattern load
08-30-2011 11:58 PM in reply to: SWModeller
You can try to define several live load cases with surface loads on a contours (one load in each of the load case) and then generate either automatic or manual combinations using the combination wizard (Loads > Automatic Combinations). The limit of combinations can be set in Job Preferences.
Artur Kosakowski
Active Contributor
PatrickSt-Louis5310
Re: Pattern load
12-14-2013 06:05 PM in reply to: Artur.Kosakowski
I Think that SWModeller, want to do it in the same way that CSI SAFE is doing it, means in two way automatic patern live on the surface area of the slab, and a custon surface area simila to what you have proposed with ARSA
