How to practically apply pattern load from specially loads for multi-span slab in Robot 2011?
Is there any limit for slab geometry/layout when use pattern load method?
Solved by Artur.Kosakowski. Go to Solution.
You can try to define several live load cases with surface loads on a contours (one load in each of the load case) and then generate either automatic or manual combinations using the combination wizard (Loads > Automatic Combinations). The limit of combinations can be set in Job Preferences.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
