I have a patch load defined by a contour which I want to repeat on several storeys of my building. Is there a simple way of duplicating this load without having to redefine it on each storey?
Thank you
Chrismcc
Solved by Rafal.Gaweda. Go to Solution.
I am afraid that there is no simple way...You may define some geometrical objects to define the contour and then copy then...
Didn't know that one...
Good!
Is there already a way to do it if the load repeats but at the same level. I mean, can the contour load be copied horizontally(together with the panel)?
Rafael Medeiros
Rafal,
Thank you. I like that - often wondered about "projected load".
I am pleased to see that the question generated some interest.
Regards
Chrismcc
No, there is no such possibility.
