I'm analysing an existing steel structure that needs to be reinforced. At this point i'm looking to beams/rafters between brackets (bars 1106to1113). The steel section that exist actually is an IPE and we will reinforce by welding to bottom flange a part of other IPE or plates. To calculate this reiforcement i've used cross section on parametric steel section.
My problem is when i'm running member verification i get the message that robot didn't perform lateral buckling analysis because section type or because it doesn't exist bending. I checked and exist bending, so please confirm me if robot doesn't perform lateral buclkling analysis to this section. If it doesn't, can you give me an idea how to design final reinforced structure?
Model: http://we.tl/x0I7nwk0Vp
Thanks in advance,
RRufino
Solved by Rafal.Gaweda. Go to Solution.
Solved by Artur.Kosakowski. Go to Solution.
LTB is not supported for such section types (I think EC3 does not include such provisions).
I would create the section as the user defined inside the Section Builder module assigning it the I type. This would allow for code checking based on rules given in the code for such sections (including the LTB check).
Tools \ Section Database, open database, mark whole record (with this section) in table part of this window, press DEL key on keyboard, close Section Database viewer.
