During parametric/special section verification (SFB in my case, HEB+plate) RSA shows ratio and forces only for shear or only for bending, depends on which one is governing. For standart profiles all forces and all ratios are displayed...
Solved by Artur.Kosakowski. Go to Solution.
This happens when the verification point is either at the bar's end (My =0) or in its middle (FZ = 0) and is correct but when both values are not zeros at the verification point I can't see any issue
When you try to optimize the beams using SFB profile family, Robot crash or freeze. The same it happened with IFB ones.
Could you send the sample file? What was the way you created these families?
