Discussion Groups
Robot Structural Analysis
stroxy
Accepted Solution
Panel Modification
161 Views, 1 Replies
12-28-2011 10:06 PM
I have a recatangular panel, representing a raft foundation.  I want to modify the area under the lift (elevator) core walls by dropping it deeper (to accomodate lift equipment) , what is the best workflow to achieve that,short of remodelling the whole panel from scratch?
Please use plain text.
Product Support
Artur.Kosakowski
Re: Panel Modification
12-28-2011 11:18 PM in reply to: stroxy
1. Create the opening within the lift area inside the existing raft foundation
2. Create a panel of the size of the opening below the existing raft foundation
3a. Create vertical panels to connect edges of the opening with edges of the newly created panel
or
3b. Use rigid links to connect nodes generated along the edges of the opening with the corresponding nodes of the panel you created below the opening
Artur Kosakowski
