Discussion Groups
Robot Structural Analysis
Valued Mentor
tony.ridley
Panel Maps after non-linear analysis
137 Views, 6 Replies
04-12-2012 04:06 PM
Hi guys,
When I run a shell element with a non-linear analysis, the results map is just black.
It only goes black when the layer is on "middle".  I get a normal map when the layer is upper or lower.
Is this an error in the program, or am I doing something wrong?
Tony
Please use plain text.
Product Support
Artur.Kosakowski
Re: Panel Maps after non-linear analysis
04-12-2012 11:12 PM in reply to: tony.ridley
Tony,
What kind of results you display (stresses)? Please check the values for the middle layer in the panel results table - are they 0s?
Artur Kosakowski
Valued Mentor
tony.ridley
04-13-2012 07:16 AM in reply to: Artur.Kosakowski
Artur,
No, it is black for stresses in middle layer only for non linear combinations.
For the simple cases it works fine.
Upper and lower stresses report correctly, just not middle.  But there IS stress in the middle layer.  So I'm not sure whats going on
Tony
Product Support
Artur.Kosakowski
04-13-2012 07:41 AM in reply to: tony.ridley
Tony,
Please send us both the model and screen capture that shows what to look at (and how it looks on your machine). Thank you.
Artur Kosakowski
Valued Mentor
tony.ridley
04-13-2012 07:42 AM in reply to: tony.ridley
file here:
Valued Mentor
tony.ridley
04-13-2012 07:50 AM in reply to: tony.ridley
hmmm told you I was having a bad Robot day.  It seems when I run the file I sent to you, it works OK.  I only opened it in recovery to cut down the file size, but it seems to have fixed the problem too.
Sorry for posting without trying this first.  :smileyembarrassed:
Tony
Product Support
Artur.Kosakowski
04-13-2012 07:53 AM in reply to: tony.ridley
Good to know it works (I was about to send you a nice picture with lot of colors) :smileyhappy:
Artur Kosakowski
