Discussion Groups
Robot Structural Analysis
7 Kudos
Panel load distribution
375 Views, 5 Replies
01-04-2012 07:56 AM
Hi All,
I am trying to analyze a structure using a unidirectional slab without f.e.. The verification of the structure give always the same advice " The he load  ...." as shown in the picture.
The distribution of load seems anyway correct as shown in the picture.
Any suggestion, How I can understand if and where the things are going wrong ?
Product Support
1,305 Kudos
Re: Panel load distribution
01-04-2012 08:30 AM in reply to: GabrieleNovembri1027
On my simple model everything works fine.
Please send me your model
Rafal Gaweda
7 Kudos
01-04-2012 10:18 AM in reply to: Rafal.Gaweda
Hi Rafal,
You will find attached the RTD file of the part of the model that causes the error. It is portion of a very big structure and I have isolated the part with the problem as shown in the picture (the attached file is only a little part of the substructure in the picture). I have created constraints and so you can run the analysis. The selected panels give the error.
Product Support
1,305 Kudos
01-05-2012 01:15 AM in reply to: GabrieleNovembri1027
You are right. Loads are generated correctly but the misleading (in this case) warning message is displayed.
One hint: if you want to neglect some bars in claddings loads generation use Geometry \ Additional Attributes \ Loads Distribution Options -> .... Ignore
Rafal Gaweda
7 Kudos
01-05-2012 02:36 AM in reply to: GabrieleNovembri1027
7 Kudos
01-05-2012 02:37 AM in reply to: GabrieleNovembri1027
Hi Rafal,
Thanks a lot.
