Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Panel Edge Modification
13 REPLIES 13
Message 1 of 14
stroxy
2726 Views, 13 Replies
Is there a way to divide a panel edge without dividing the edge on the opposite side of the panel?
Is there a way to join panel edges that have been divided?
13 REPLIES 13
Message 2 of 14
Artur.Kosakowski
in reply to: stroxy
Here you are.
See also: http://forums.autodesk.com/t5/Autodesk-Robot-Structural/editing-slab-contour-geometry/m-p/3223160/hi...
Artur Kosakowski
Message 3 of 14
How to select panel edge? When I click on edge, only whole panel selected
Message 4 of 14
Hi @antoshka_2012
Try these steps:
Artur Kosakowski
Message 5 of 14
Rafal.Gaweda
in reply to: stroxy
Hi @stroxy
Here you can find the macro to delete intermediate points automatically.
Rafal Gaweda
Message 6 of 14
Please try to divide top edge for this one in atteched file
Message 7 of 14
@antoshka_2012
I assume that what you really want is the control over meshing. If so try these steps:
Artur Kosakowski
Message 8 of 14
Rafacascudo
in reply to: antoshka_2012
I am not sure you can do that because that edge is an arc segment.
What you can do is redo the panel increasing the numer of sides on arc discretization.
Rafael Medeiros
Message 9 of 14
Hi @Rafacascudo
The similar effect can be obtained in this way:
Artur Kosakowski
Message 10 of 14
Yes , sure , That´s what I meant by "redo" Smiley Happy
Rafael Medeiros
Message 11 of 14
in reply to: Artur.Kosakowski
Hi, i tried dividing a wall in order to obtain better discretization of linear reactions, but it´s not working:
After aplying the Divide Tool to the edge and assigninn distance = 1m, nothing changes. I´m using a Wall with Shell model calculation.
Please i would appreciatte some help, my posts generally are not answered.
Thanks!.
Message 12 of 14
Rafacascudo
unmark "generate... "
Rafael Medeiros
Message 13 of 14
in reply to: Rafacascudo
I did, but dindn´t succeed. Model atacched in case you wanna check.
Thanks.
Message 14 of 14
Rafacascudo
set the "divide" dialog as shown,select/click the desired edge to be designed and it will ask you if it is the edge or the whole panel(all edges) to be divided . select the edge and click OK.
Rafael Medeiros
