Discussion Groups
Robot Structural Analysis
3 Kudos
Panel Edge Modification
291 Views, 1 Replies
12-29-2011 01:25 AM
Is there a way to divide a panel edge without dividing the edge on the opposite side of the panel?
Is there a way to join panel edges that have been divided?
Product Support
760 Kudos
Re: Panel Edge Modification
12-29-2011 01:41 AM in reply to: stroxy
Here you are.
See also: http://forums.autodesk.com/t5/Autodesk-Robot-Structural/editing-slab-contour-geometry/m-p/3223160/hi...
Artur Kosakowski
